The bottom row of the grid is Line
1 8 2 6 3 7 4 9 5
This one?
bottom row: 518 724 936 ?
4,3,9,1,7,2,6,5,8 bottom row
can we only use each number once in each row, column, or grid?
bottom row 7, 5, 2, 6, 1, 9, 4, 8, 3 ?
4,9,3,1,7,2,6,8,5 bottom row
Yes, it’s normal sudoku rules PLUS the other three rules. That’s why only two initial numbers are needed for a unique solution.
bottom row 174528963
9 8 2 5 4 1 6 7 3 bottom row
I understand correctly that the correct answer has not yet been given
last row is 865742319
May be that 982541673
Yup, no-one’s got it yet. I’ll mark the puzzle with [SOLVED] once the solution is found.
7, 3, 5, 6, 4, 9, 2, 8, 1
bottom row 2 8 5 6 3 9 1 7 4
okayy so the answer is:
948372615
269145378 it is last row?
The answer is 174639285
Edit: Yayyyy i won
