Avado I2 Hopr Box issues
Hello,
I am just starting a thread to document my Avado hopr box I2 issues, and would like to welcome anyone else to chime in and document their experience as well.
I have beeen running into a few issues with my Hopr box in terms of what i can handle I was hoping to be able to run both hopr package and qtum package but I dont think my box can handle it.
I installed both packages got Qtum to fully sync but ran into very slow and laggy response times on the unit. IE I would click on things like Dappstore or my Dapp and it would take about 3-10 minuets for the content to load.
I uninstalled everything cleaned up the HD space just to give it a fresh start but the issue still happens even if I just have only one of the HOPR package or the Qtum package installed.
Anyone have any suggestions on how to fix that? Or if I might be doing something wrong.
Thank you!
I will be back to update this thread as my experimenting and testing continue.
Sorry
Can’t help you.
I only can tell you, that I can run h0pR, Mysterium and Qtum on my avado box without any issue and app starting within seconds.
Have you tried to get help in the offical avado Hopr Box Telegram Channel?
Posting for posterity:
Specs for an Avado HOPR i2 Node are
CPU: Intel Pentium 4415, 2.3Ghz
Memory: 8GB [single stick]
Storage: 1TB SSD
https://hoprnet.org/node
https://ark.intel.com/content/www/us/en/ark/products/96508/intel-pentium-gold-processor-4415u-2m-cache-2-30-ghz.html
The Pentium isn’t designed to be a powerhouse, its akin to an economy server with low electrical draw and budget oriented cache.
