Thank you everyone for your participation in the discussion phase. That phase is now closed, and no more proposals can be created. Valid proposals which received signatures from more than 3% of active DAO participants have moved onto the referendum stage.
In the referendum stage, proposals need signatures from at least 15% of active participants to move forward to the vote stage. If fewer than four proposals receive 15% support, then the four proposals with the most support will move forward.
The Referendum phase will run for 22 hours, and end at 12 noon CET on October 19th. The vote will begin 2 hours later.
