I’m not sure which part of the Forum this belongs under as it is not a Hopr thing and just a message board problem. I keep getting this following pop up, even if I haven’t logged on for several days…
Does anyone have a hint on what is happening?
Hello. This is normal. You can customize notifications in your profile settings.
Thanks, I will take a look, but it also seems to mean that the heart/like is not being logged by the forum as well. Ah well, I will try and figure out if it has to something to do with using different devices and not remembering to log out?
