Thank you everyone for your participation in the discussion phase. That phase is now closed. Valid proposals which received signatures from more than 3% of active DAO participants have moved onto the referendum stage.
In the referendum stage, proposals need signatures from at least 15% of active participants to move forward to the vote stage. If fewer than four proposals receive 15% support, then the four proposals with the most support will move forward.~
The Referendum phase will run for 22 hours, and end at 12 noon CET on October 19th. The vote will begin 2 hours later.
