Proposal #13: Create a Hoprnet-SDK
[This proposal comes from @ptrnull. To support this proposal, sign it by clicking the like (heart) button beneath this post.]
Proposal
Create a Hoprnet-SDK to enable developers easily start creating and integrating their applications using the hopr network.
Scope of work:
A software development kit (SDK) is a set of tools that provides a developer with the ability to build a custom app which can be added on, or connected to, another program. SDKs allow programmers to develop apps for a specific platform.
Providing an SDK to the world will enable thousands of developers worried about privacy to start using the hopr network to secure the communications of their applications. Would be really important to provide examples on how to integrate the hopr network in an application, using libraries or modules, depending on the language.
It should be open source and available to everybody on GitHub to enable the open source ecosystem providing help with the development of new features and fixing bugs.
[To view the original discussion, click here]
