This thread is for discussing the proportional amount of assets which should be allocated to each of Arrakis and Gamma to manage, assuming both are awarded a trial to manage the DAO’s liquidity.
In general people seem to think that the projects should be awarded a trial on a 50:50 basis, but other proportions have been suggested.
This discussion is intended for people who think these amount should be greater than zero. If you don’t think either project should be chosen, you’ll have the opportunity to support this preference elsewhere.
In what ratio should assets be allocated to Arrakis and Gamma, respectively, in this experiment?
If we choose a short period and Arrakis charges 1% of the AUM regardless, i rushed with a 50:50 choice, it would probably be better to give Arrakis a smaller share.
Revocalizing this: remove 60% liquidity from Uniswap since the DAO is considered flush, then split the remaining 40% liquidity equally between Arrakis and Gamma, we’ll get a much better idea of performance without impacting Hopr’s current running 24hr Uniswap trade volume of $8K USD.
