Uniswap exchange commission average price is 30-40$. Only sometimes the price is higher. If you want to buy token with small comission - use existed spot or Honeyswap exchange. You must understand - we have only ~6k token holders - it is too small, to support multi network infrastructure.
And Vitalik proposal some changes in ETH network to reduce commission price (in june), and the end of 2021, they promise ETH 2.0. May be we can simple wait?
Of course we can wait.
There is very low liquidity on honeyswap.
I donβt see any problems even as an experiment to transfer part of the liquidity to Bsc20(pancekswap, binance dex). It may be that liquidity will increase significantly. Increase token recognition.
Look at Busd, it is being used more and more. The market share of Usdt (tether) is falling. Hoprβs presence in more markets will provide more opportunities, including for price.
I thought Binance DEX is already dead, lol. Forced me to check its data.
Do not think it is a good idea as it is not popular at all.
It also a bit difficult for newbies and it does not support metamask, so it discourage people from using it
Why did you vote for the Honeyswap a few months ago? trading volume is even smaller. My suggestion is to switch partially to bsc20. Please read: Suggestion: 3 chains 4 Dex
Binance is the largest centralized exchange.
Did you mean exchanges using the bsc network?
One of them is Pancakeswap. Oh yes, the exchange is one of the largest.
